SDRuno on Linux
Re: SDRuno on Linux
Postby sdrplay » Wed Feb 22, 2017 11:06 am
What's important is how you have built the wxWidgets
For me I have the following structure...
/home/sdrplay/Dev/wxWidgets-3.1.0
/home/sdrplay/Dev/wxWidgets-staticlib
so you need to be careful when building wxWidgets that the correct path for the output is specified. Then make sure that same path is used in the CubicSDR build.
What's your wxWidgets cmake command look like?
octave9
Re: SDRuno on Linux
Postby octave9 » Wed Feb 22, 2017 11:56 am
wxWidgets doesn't use cmake. The make I used was the two line variety. From cli history it went:
tar -xvjf wxWidgets-3.1.0.tar.bz2
cd wxWidgets-3.1.0/
./autogen.sh
./configure --with-opengl --disable-shared --enable-monolithic --with-libjpeg --with-libtiff --with-libpng --with-zlib --disable-sdltest --enable-unicode --enable-display --enable-propgrid --disable-webkit --disable-webview --disable-webviewwebkit --prefix=`echo ~/SDR-Dev/wxWidgets-staticlib` CXXFLAGS="-std=c++0x"
make -j4
make install
The previous doc. I followed had 'make j4 && make install' both work, of course.
Thanks though. You and others obviously have it working, so it must be something wrong on my end. I'll have another look when I get some time.
octave9
Re: SDRuno on Linux
Postby octave9 » Fri Feb 24, 2017 1:03 pm
Got my RSP2 yesterday. Tried it briefly on my Windows PC with both SDRUno and HDSDR. No problems and SDRUno looks and feels wonderful, albeit with rather small text on 1440p. Couldn't get either to work with RDP as Windows 7 disables system audio when that protocol is used for connections...
Got further with CubicSDR on Linux. Apparently cmake can't stand hyphens on the command line in filenames. So my 'SDR-Dev' folder broke it. Yup. I was shocked too, especially when I realised it applies to the darn 'wxWidgets-staticlib' part of the instructions as well. Means the original "Build static wxWidgets" instructions at https://github.com/cjcliffe/CubicSDR/wiki/Build-Linux are wrong too.
So the wxWidgets config line I used was:
./configure --with-opengl --disable-shared --enable-monolithic --with-libjpeg --with-libtiff --with-libpng --with-zlib --disable-sdltest --enable-unicode --enable-display --enable-propgrid --disable-webkit --disable-webview --disable-webviewwebkit --prefix=`echo ~/SDR_Dev/wxWidgets_staticlib` CXXFLAGS="-std=c++0x"
CubicSDR build's 'cmake' modified line then works but then it fails at the 'make' like:
john@Mint-18 ~/SDR_Dev/CubicSDR/build $ cmake ../ -DCMAKE_BUILD_TYPE=Release -DwxWidgets_CONFIG_EXECUTABLE=~/SDR_Dev/wxWidgets_staticlib/bin/wx-config
-- The C compiler identification is GNU 5.4.0
-- The CXX compiler identification is GNU 5.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
64 bit compiler detected
-- Found OpenGL: /usr/lib/x86_64-linux-gnu/libGL.so
-- Found LIQUID: /usr/local/lib/libliquid.so
-- Found wxWidgets: -L/home/john/SDR_Dev/wxWidgets_staticlib/lib;-pthread;;;/home/john/SDR_Dev/wxWidgets_staticlib/lib/libwx_gtk2u_gl-3.1.a;-lGL;-lGLU;/home/john/SDR_Dev/wxWidgets_staticlib/lib/libwx_gtk2u-3.1.a;-lgtk-x11-2.0;-lgdk-x11-2.0;-lpangocairo-1.0;-latk-1.0;-lcairo;-lgdk_pixbuf-2.0;-lgio-2.0;-lpangoft2-1.0;-lpango-1.0;-lgobject-2.0;-lfontconfig;-lfreetype;-lgthread-2.0;-pthread;-lglib-2.0;-lX11;-lXxf86vm;-lSM;-lgtk-x11-2.0;-lgdk-x11-2.0;-lpangocairo-1.0;-latk-1.0;-lcairo;-lgdk_pixbuf-2.0;-lgio-2.0;-lpangoft2-1.0;-lpango-1.0;-lgobject-2.0;-lglib-2.0;-lfontconfig;-lfreetype;-lpng;-lz;-ljpeg;-lwxregexu-3.1;-lwxtiff-3.1;-lz;-ldl;-lm (found version "3.1.0")
-- Copying /home/john/SDR_Dev/CubicSDR/font/*.fnt to directory /home/john/SDR_Dev/CubicSDR/build/x64/fonts
-- Configuring file vera_sans_mono36.fnt
-- Configuring file vera_sans_mono48.fnt
-- Configuring file vera_sans_mono18.fnt
-- Configuring file vera_sans_mono27.fnt
-- Configuring file vera_sans_mono16.fnt
-- Configuring file vera_sans_mono64.fnt
-- Configuring file vera_sans_mono24.fnt
-- Configuring file vera_sans_mono32.fnt
-- Configuring file vera_sans_mono12.fnt
-- Configuring file vera_sans_mono96.fnt
-- Configuring file vera_sans_mono72.fnt
-- Copying /home/john/SDR_Dev/CubicSDR/font/*.png to directory /home/john/SDR_Dev/CubicSDR/build/x64/fonts
-- Copying /home/john/SDR_Dev/CubicSDR/icon/CubicSDR.ico to directory /home/john/SDR_Dev/CubicSDR/build/x64
-- Configuring file CubicSDR.ico
-- Configuring done
-- Generating done
-- Build files have been written to: /home/john/SDR_Dev/CubicSDR/build
john@Mint-18 ~/SDR_Dev/CubicSDR/build $ make
Scanning dependencies of target CubicSDR
[  1%] Building CXX object CMakeFiles/CubicSDR.dir/external/rtaudio/RtAudio.cpp.o
/home/john/SDR_Dev/CubicSDR/external/rtaudio/RtAudio.cpp:8097:25: fatal error: pulse/error.h: No such file or directory
compilation terminated.
CMakeFiles/CubicSDR.dir/build.make:62: recipe for target 'CMakeFiles/CubicSDR.dir/external/rtaudio/RtAudio.cpp.o' failed
make[2]: *** [CMakeFiles/CubicSDR.dir/external/rtaudio/RtAudio.cpp.o] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/CubicSDR.dir/all' failed
make[1]: *** [CMakeFiles/CubicSDR.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
I struggled a bit with that one. So what now? Any help would be appreciated.
deadite66
Re: SDRuno on Linux
Postby deadite66 » Fri Feb 24, 2017 1:59 pm
is libpulse-dev installed?
Airspy R2 on a Discone
SDRPlay RSP2 Pro on a choc bloc copper dipole.
Yupiteru MVT-9000 MKII telescopic ant.
Adalm Pluto (hacked for 70MHz-6GHz)
octave9
Re: SDRuno on Linux
Postby octave9 » Fri Feb 24, 2017 2:22 pm
deadite66 wrote:
It is now and building :) 45%...
Many thanks.
Builds, installs and runs, but no time to test 'till later...
deadite66
Re: SDRuno on Linux
Postby deadite66 » Sat Feb 25, 2017 7:18 pm
nice :)
