Nothing But Noise on SDRUno
Posted: Tue Apr 18, 2017 10:15 pm
by Royce
Last year I bought an SDRPlay at Dayton Hamvention. I downloaded the SDR Console and everything worked great. Recently I found out about this SDRUno software, so I decided to try it. I downloaded and installed SDRUno, Then I tuned to a local FM Broadcast station that I listen to on the SDR Console. I got nothing but noise. I started pushing all the buttons and switches to try and get rid of the noise. I tried the noise blanker, wide vs. narrow FM, different filters, reducing IF gain and so on and so forth. Nothing changed. This is a local station and I couldn't even hear any indication of a signal or any audio. Nothing but noise. Then I tried other frequencies and modes, AM, LSB, USB, etc.. No difference. Nothing but noise. Has anyone had this happen and what did you do to fix it ? Or can it be fixed ?
By the way I am using a 73 ft. long dipole with a balun as an antenna, and an older HP Laptop that runs Windows Vista. I also have Linux Ubuntu ver. 14 installed for a dual boot capability. I wonder if trying a Linux version of SDRUno would work better ?
Re: Nothing But Noise on SDRUno
Posted: Wed Apr 19, 2017 8:58 am
by Tech_Support
Dear Royce,
Please double check that you have programmed the frequency correctly. The frequency is entered in kHz in SDRuno, so, for 100 MHz, you need to enter 100000. If you continue to have problems, please post screen shots showing your settings or open up a support ticket with SDRplay directly.
Posted: Wed Apr 19, 2017 10:46 pm
by Royce
I uninstalled SDRUno and then reinstalled. Then I tried it again. I finally managed to get it working correctly. I think it was a combination of something not installing correctly the first time and my entering some of the frequencies incorrectly as you identified in your reply. Everything seems to be working fine now.
Posted: Fri Jul 14, 2017 2:30 am
by N0WAM
My SDRUno was working great and then a week later when I went to use it - it would not work....
it no longer plays anything but noise and I cannot seem to change the frequency.
Something is locked up... I see Royce was able to uninstall Uno - and then install it again.
I guess I need to do that... if I can figure out how to do it...
Posted: Fri Jul 14, 2017 5:44 pm
by Peterv1036
Same here. Reinstalled SDRUNO again and nothing but noise. Cannot even receive weather on an outdoor discone. Fed signal generator on the displayed frequency and nothing but noise. Defective? Tried both antenna inputs.
Posted: Fri Jul 14, 2017 6:12 pm
by dlritter
Well I had a simular problem.. but it was nice music..
check to be sure you only have 1 VRX open..
on the main page you should have just one line:
0 sp1 sp2 rx green
not
0 sp1 sp2 rx green
1 sp1 sp2 rx green
ur vrx 0 is on noise and vrx1 might have the command focus.
Posted: Fri Jul 28, 2017 6:21 pm
by Peterv1036
Found my problem. Cockpit error! Not enough 0s to properly enter a frequency. Working on a LF antenna. Random wire very noisy. Thanks for the suggestion.
Posted: Fri Jul 28, 2017 11:13 pm
by g1hbe
Frequency entry is a major bugbaer with me. It would be much better with separate keys for KHz and MHz, so you could enter 200K or 200M and be there in an instant instead of wondering about all those zeros. My Signal Hound spectrum analyser uses this method and it's a breeze!
Posted: Sat Jul 29, 2017 5:53 am
by Paul
The direct frequency entry in SDRradio Console is quite straightforward - enter frequency in Mhz.Khz.
However, I find that in general SDRUno meets my requirements better although Console does have some attractive features
For my money the little 0's "agro" in SDRUno isn't too bad a price to pay for the rest of it's functionality, although I do think that an Mhz.Khz would be preferable - easier/quicker to use (but then all the real Hams out there would likely disagree).
Posted: Thu Aug 31, 2017 7:46 am
by G4HPW
I agree with the comments about frequency entry which makes the software a pain to use. :evil:
Entering a frequency in kHz is not intuitive in any way and is especially painful above 1GHz.
On the whole SDR Console is way better in many respects than sdruno.
