RSP2 Question
Pascha
RSP2 Question
Postby Pascha » Fri Oct 13, 2017 10:31 am
Hello
I bought a RSP2 and today I try to connect it to my Mac, but nothing happens. I tried CubicSDR and GQRX but both do not find my RSP2. I tried several USB cable . The API driver is installed. Please help.
Regards Guenter from Germany.
Re: RSP2 Question
Postby sdrplay » Fri Oct 13, 2017 12:35 pm
Either click refresh in the CubicSDR device selection window (there is a bug that requires the RSP to be discovered twice on some Mac machines) or if that doesn't work, type the following into a command prompt and post the results...
SoapySDRUtil --probe=sdrplay
You can always contact us on Support (http://www.sdrplay.com/support) and we'll be able to help you.
Pascha
Re: RSP2 Question
Postby Pascha » Fri Oct 13, 2017 2:55 pm
Hello, now it works, but unfortunately I can not adjust bandwidth, or antenna input, etc. as in the SDRuno software. Is this not possible?
regards
Re: RSP2 Question
Postby sdrplay » Fri Oct 13, 2017 2:59 pm
Yes, go back to the device selection menu and you can change both. I believe in the latest version of the hardware library that works with CubicSDR you can change those items from the CubicSDR menu directly.
mark.
Re: RSP2 Question
Postby mark. » Fri Oct 13, 2017 8:51 pm
For future reference, which one of the 2 suggestions fixed the issue of not running on your Mac?
