Nothing works...
TotalHavoc
Nothing works...
Postby TotalHavoc » Sun Apr 08, 2018 12:33 pm
Hi all. I've been using GQRX on Fedora 23...27 since ages with RTL282 cheap USB keys correctely working.
I'm not a developper and I don't want to become one.
I bought this new SDRplay RSP1A hoping this would be a better experience but nothing works at all. I was told that this RSP1A would work fine with GQRX but in fact it is simply not seen by my system (up-to-date).
This device is not recognized by any libraries installed, even the one downloaded on the manufacturer site. I downloaded a ton of RPM with all the dev tools known, sources, devel-packages, nothing.
rtl-sdr or gr-osmosdr are at latest version but don't see the device, despite it's identified as USB 1df7:3000
The cc/cpp/gcc compilers/preprocessors are installed but the "workflow" for non windoze OS stops with:
[root@hercules build]# cmake ../
-- The C compiler identification is GNU 7.3.1
-- The CXX compiler identification is unknown
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
CMake Error at CMakeLists.txt:5 (project):
No CMAKE_CXX_COMPILER could be found.
When trying to issue cmake ../ -DCMAKE_CXX_COMPILER=/usr/bin/cpp (with verified cpp at right location) the result is merely the same:
(Nearly same result with "cpp" or "gcc" or "cc")
[root@hercules build]# cmake ../ -DCMAKE_CXX_COMPILER=/usr/bin/cpp
-- Check for working CXX compiler: /usr/bin/cpp
-- Check for working CXX compiler: /usr/bin/cpp -- broken
CMake Error at /usr/share/cmake/Modules/CMakeTestCXXCompiler.cmake:45 (message):
The C++ compiler
"/usr/bin/cpp"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: /root/Dev/SoapySDR/build/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/gmake" "cmTC_fb82a/fast"
/usr/bin/gmake -f CMakeFiles/cmTC_fb82a.dir/build.make CMakeFiles/cmTC_fb82a.dir/build
gmake[1] : on entre dans le répertoire « /root/Dev/SoapySDR/build/CMakeFiles/CMakeTmp »
Building CXX object CMakeFiles/cmTC_fb82a.dir/testCXXCompiler.cxx.o
/usr/bin/cpp -o CMakeFiles/cmTC_fb82a.dir/testCXXCompiler.cxx.o -c /root/Dev/SoapySDR/build/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
cpp: erreur fatale: « -c » n'est pas une option valide pour le préprocesseur
compilation terminée.
gmake[1]: *** [CMakeFiles/cmTC_fb82a.dir/build.make:66: CMakeFiles/cmTC_fb82a.dir/testCXXCompiler.cxx.o] Error 1
gmake[1] : on quitte le répertoire « /root/Dev/SoapySDR/build/CMakeFiles/CMakeTmp »
gmake: *** [Makefile:126: cmTC_fb82a/fast] Error 2
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
-- Configuring incomplete, errors occurred!
See also "/root/Dev/SoapySDR/build/CMakeFiles/CMakeOutput.log".
See also "/root/Dev/SoapySDR/build/CMakeFiles/CMakeError.log".
I do precise that I won't switch to ubuntu or other exotic distros, my personnal/professional world is RHEL/Fedora/Centos and, of course, no MS.
Should I ask for... a refund ?!?
Regards
