RSP1a and BIAS-T
Post your feedback here
ekendraed
RSP1a and BIAS-T
Postby ekendraed » Mon May 07, 2018 2:36 am
In the RSP1a is the BIAS-T switched ON or OFF from within SDRUNO?
Re: RSP1a and BIAS-T
Postby g1hbe » Mon May 07, 2018 11:40 am
Yes, I believe there is a button in the 'main' window.
ekendraed
Postby ekendraed » Mon May 07, 2018 11:58 am
Noted. Thank you
Otherwise the RSP1a could be damaged if connected to a SLIM JIM like receiving antenna.
4S7EF
Postby g1hbe » Mon May 07, 2018 12:08 pm
I think there is an over-current trip which turns off the bias-T if more than 100mA is drawn. From the datasheet:
4.7V /100mA Guaranteed.
Note : Bias T has an over current protection circuit. Current in excess of 100mA will cause the
bias T voltage to disable. Removal of the overcurrent condition and a reset of the bias T
control will re-establish the voltage
ekendraed
Postby ekendraed » Mon May 07, 2018 12:17 pm
Thank you
ekendraed
Postby ekendraed » Tue May 22, 2018 1:58 am
Mike SDR has confirmed that it is POLY FUSED and that NO HARM will come to the Bias-T port.
"A "polyfuse" is a fuse made from a polymer. It is a fuse that after it has "blown" will self heal; that is after several days, it will (almost) behave as if nothing has happened. "
For further reading see "https://elinux.org/Polyfuses_explained"
Thanks Mike.
Postby Tech_Support » Tue May 22, 2018 7:20 am
Err, there is a bit of confusion here. The Bias-T is not poly-fused. It has an overcurrent reset on it. Drawing too much current will simply shut the bias-T down. To get it back on you need to cycle the control for it, but it will turn back on instantly.
ekendraed
Postby ekendraed » Tue May 22, 2018 7:34 am
Thank you for the correction and clarification. 4S7EF
mikexeno
Postby mikexeno » Wed Dec 26, 2018 5:23 pm
I don't recall saying that the BIAS T was poly fused.
