RSP1a only noise
RSP1a only noise
I am the happy owner of a new RSP1a
- switched from a noname RTL dongle which worked perfect
My problem is that all I have is noise
- even nearby FM stations cannot be heard
Reinstalled SDRuno 1.22 three times
Probably in settings - but where
/ John
/ John
Re: RSP1a only noise
If you could post a picture of your screen we may be able to spot the problem.
Also screw your antenna into another radio to make sure the antenna,cable and connectors are good.
Have tested the antenna with another receiver and it is OK
The receiver works perfect with HDSDR
- screendump attached
/ John
/ John
- sdrunodump.png (500.15 KiB) Viewed 18652 times
Hello John,
You are tuned to 107.2 kHz, not 107.2 MHz.
Nice sunday morning here in Denmark
- and tuned to the correct freqency it all works very well
Thanks, and have a nice day
/ John
/ John
