RSP1a only noise
Posted: Fri Jun 22, 2018 3:26 pm
by Johntk56
I am the happy owner of a new RSP1a
- switched from a noname RTL dongle which worked perfect
My problem is that all I have is noise
- even nearby FM stations cannot be heard
Reinstalled SDRuno 1.22 three times
Probably in settings - but where
/ John
Re: RSP1a only noise
Posted: Fri Jun 22, 2018 4:58 pm
by g1hbe
If you could post a picture of your screen we may be able to spot the problem.
Posted: Sat Jun 23, 2018 3:26 am
by mark.
Also screw your antenna into another radio to make sure the antenna,cable and connectors are good.
Posted: Sat Jun 23, 2018 10:01 pm
by Johntk56
Have tested the antenna with another receiver and it is OK
The receiver works perfect with HDSDR
- screendump attached
/ John
Posted: Sun Jun 24, 2018 5:25 am
by Tech_Support
Hello John,
You are tuned to 107.2 kHz, not 107.2 MHz.
Posted: Sun Jun 24, 2018 7:48 am
by Johntk56
Nice sunday morning here in Denmark
- and tuned to the correct freqency it all works very well
Thanks, and have a nice day
/ John
