CubicSDR+SoapySDR trouble
hermit
Postby hermit » Wed Aug 22, 2018 9:18 am
I'm trying to get my new SDRplay working. I've installed the API driver and built the SoapySDR module, which seem to work as it should:
$ SoapySDRUtil --probe=sdrplay
##     Soapy SDR -- the SDR abstraction library     ##
Probe device sdrplay
-- Device identification
  driver=SDRplay
  hardware=180801E211
  mir_sdr_api_version=2.130000
  mir_sdr_hw_version=2
-- Peripheral summary
  Channels: 1 Rx, 0 Tx
  Timestamps: NO
  Other Settings:
       [key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8)]
     * ExtRef Enable - External Reference Control
       [key=extref_ctrl, default=true, type=bool]
-- RX Channel 0
  Full-duplex: YES
  Supports AGC: YES
  Stream formats: CS16, CF32
  Antennas: Antenna A, Antenna B, Hi-Z
  Corrections: DC removal
  Full gain range: [0, 47] dB
    IFGR gain range: [20, 59] dB
    RFGR gain range: [0, 8] dB
    CORR freq range:  MHz
  Sample rates: 0.25, 0.5, 1, 2, 2.048, 6, 7, 8, 9, 10 MSps
  Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
But CubicSDR doesn't recognize the SDRplay.
I've installed CubicSDR 0.2.4 from the debian repository. How do i add SDRplay to CubicSDR?
hermit
Re: CubicSDR+SoapySDR trouble
Postby hermit » Wed Aug 22, 2018 10:23 am
Meanwhile I found out that the reason is an ABI version mismatch:
sdrplay failed ABI check: Library ABI=0.6, Module ABI=0.7
Haven't found a solution yet though.
hermit
Postby hermit » Wed Aug 22, 2018 11:23 am
Nevermind. I found out how to build the module for 0.6, everything is working now. Thanks.
ehidle
Postby ehidle » Fri Dec 28, 2018 5:06 pm
Would you please share? I am having this issue now as well. Thanks!
Tacoma21
Postby Tacoma21 » Fri Jan 25, 2019 1:33 am
Yes, please post how you did this. I have the API and SoapySDR built but cannot get CubicSDR to recognize the SDRPlay.
Users browsing this forum: Google [Bot] and 1 guest
