CubicSDR+SoapySDR trouble
Posted: Wed Aug 22, 2018 9:18 am
I'm trying to get my new SDRplay working. I've installed the API driver and built the SoapySDR module, which seem to work as it should:
But CubicSDR doesn't recognize the SDRplay.
I've installed CubicSDR 0.2.4 from the debian repository. How do i add SDRplay to CubicSDR?
$ SoapySDRUtil --probe=sdrplay
## Soapy SDR -- the SDR abstraction library ##
Probe device sdrplay
-- Device identification
driver=SDRplay
hardware=180801E211
mir_sdr_api_version=2.130000
mir_sdr_hw_version=2
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
[key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8)]
* ExtRef Enable - External Reference Control
[key=extref_ctrl, default=true, type=bool]
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS16, CF32
Antennas: Antenna A, Antenna B, Hi-Z
Corrections: DC removal
Full gain range: [0, 47] dB
IFGR gain range: [20, 59] dB
RFGR gain range: [0, 8] dB
CORR freq range: MHz
Sample rates: 0.25, 0.5, 1, 2, 2.048, 6, 7, 8, 9, 10 MSps
Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
