Enhancement request for SDR Uno
Toontje
Postby Toontje » Mon Oct 15, 2018 12:25 pm
SDR Uno is used as pan adapter for a TS-590. Workflow is as follows:
- Select a frequency either on the radio or on SDR Uno.
- Change the band on SDR Uno. The radio switches band as well.
- Change the band on the radio. SDR Uno doesn't change band.
It would be nice if SDR Uno would switch band whenever i switch band on the radio.
Ton.
Roger
Re: Enhancement request for SDR Uno
Postby Roger » Mon Oct 15, 2018 4:26 pm
SDRuno will track the radio and switch bands if you turn off LO Lock. Whenever you use the keypad in SDRuno to select a band it will set the sample rate, decimation and mode and turn on LO Lock. After that any command from the radio to change to a frequency outside the selected band will be ignored. So if you want SDRuno to change bands, based on radio commands, you must turn off Lo lock every time you make an SDRuno keypad band change.
