Newbie Help - decoding am & ssb
PeteL22151
Post by PeteL22151 » Sat Dec 26, 2015 4:25 pm
I'm able to receive solid signals on my displays in all modes, but for some reason I am only able to decode the audio for FM ... other modes are silent, and I can't figure out which settings need to be adjusted for AM, SSB, etc., modes. This situation has developed over the last day, since I earlier had been able to decode the audio for AM broadcast and ham SSB (both LSB & USB). I must have "tweaked" something that won't produce audio for anything but FM. Again, I'm seeing strong signals on my display, but it just doesen't produce any audio (complete silence ... not even any spectrum noise). I'm using the latest version of SDR-Console, and am connected to an off-center fed dipole. Any suggestion on what I need to adjust will be appreciated.
Thanks! Pete / N4PJL
Re: Newbie Help - decoding am & ssb
Post by jon » Wed Dec 30, 2015 10:32 am
I'm assuming you fixed this. If not, send an email to support@sdrplay.com and we'll help you out! Jon
gnasrg64
Post by gnasrg64 » Sun Feb 21, 2016 10:04 pm
Hi Pete, I'm new with SDRplay expecence and I'got your same problem: I am only able to decode the audio for FM ... other modes AM SSB are silent.
I'm seeing strong signals on my display, but it just doesn't produce any audio but only noise
Did you fix it ? Did you change some setting or preference ?
I use a PA0RDT Mini Whip antenna and work good with my receiver Tecsun PL880.
ciao,thanks in advance,Sergio (Italy)
