Looking for help with SDRplay and Ubuntu
Posted: Sun Mar 13, 2016 4:21 am
Hi all, I was recently given an SDRplay and I'm trying to get it working with a Ubuntu laptop with GNURADIO but having some difficulty. I'm completely sure the difficulty stems from my being a beginner with both SDRplay and Linux... Nevertheless, it's what I have on hand so I'm giving it my best! I've followed the instructions found on the SDRplay Linux page and get the below results when I test the "SoapySDR" install and OSMOSDR install:
Any help would be GREATLY appreciated!!!
$ SoapySDRUtil --probe=sdrplay
Probe device sdrplay
mir_sdr_Init: gR=40dB fs=2.048MHz rf=222.064MHz bw=1.536MHz if=0.000MHz
Warning: libusb_claim_interface() -6
mir_sdr_2500_Init: revisionId = 0x0200, doing FW update
fwDownload: FW image size = 6008
mir_sdr_2500_Init: fnaddr = 4
initHw: Register7 = 0x000005
initHw: Tuner Register0 = 0x04f440
mir_sdr_SetFs: Sample Freq requested 2047999.978065
mir_sdr_SetFs: Fs->FsNomHz+dFsHz=2048000.0+0.0Hz=2048000.0Hz FsToggle->1
mir_sdr_SetRf: f->222064000.000Hz (int=25 frac=20 afc=0) fSynth:3553024000.000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=222064000.0+0.0+0.0Hz+0.0Hz=222064000.0Hz RfToggle->1
mir_sdr_SetGr: GR->40[16,24,0,0] gRset->0x210 DCCALmode=4 DCCALspd=1 GrToggle->1
setToggleStates: initialising sampNum=0x0001f802, gainSetting=0x210, FsToggle=0, RfToggle=1, GrToggle=1
setToggleStates: initialising Fs=2047999.978, Rf=222064000.000, Gr=40
mir_sdr_2500_Readback001Trim: readback = 0xe301610
mir_sdr_2500_Bypass001Trim: reg13=0x20d reg14=0x6c016e
-- Device identification
driver=SDRPlay
hardware=SDRPlay
mir_sdr_version=1.700000
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
* Low IF (when available) - Use low IF when available: 0.5MHz SR with 200 and 300khz BW, 1MHz SR with 600kHz BW, 2048kHz SR with 1536kHz BW
[key=use_low_if, default=true, type=bool]
-- RX Channel 0
Full-duplex: YES
Supports AGC: NO
Stream formats: CS16, CF32
Native format: CS16 [full-scale=2048]
Antennas: RX
Corrections: DC removal, DC offset
Full gain range: [0, 204] dB
TUNER gain range: [0, 102] dB
LNAT gain range: [0, 102] dB
Full freq range: [0.1, 2000] MHz
RF freq range: [0.1, 2000] MHz
Sample rates: [0.222222, 12] MHz
Filter bandwidths: [0.2, 8] MHz
$ osmocom_fft -a soapysdr -v
linux; GNU C++ version 4.8.2; Boost_105400; UHD_003.005.005-0-unknown
gr-osmosdr 0.1.1 (0.1.1) gnuradio 3.7.2.1
built-in source types: file osmosdr fcd rtl rtl_tcp uhd hackrf bladerf rfspace
FATAL: No supported devices found to pick from.
Trying to fill up 1 missing channel(s) with null source(s).
This is being done to prevent the application from crashing
due to gnuradio bug #528.
Source has no sample rates (wrong device arguments?).
driver=SDRPlay
hardware=SDRPlay
Timestamps: NO
Other Settings:
-- RX Channel 0
Full-duplex: YES
Supports AGC: NO
Antennas: RX
