The solution, which was buried somewhere in the instructions for CubicSDR, is to install the SDRplay API "package", compile and install SoapySDR from github, compile and install SoapyRTLSDR from github, and compile and install SoapySDRPlay from github. That last step overwrites the faulty library that sdrplay.com is giving us to install.
So, let's see if I can recreate this.
1) Install SDRplay API from sdrplay.com
rec@pixil:~/Downloads$ sh SDRplay_RSP_MiricsAPI-1.9.4.run
Verifying archive integrity... All good.
Uncompressing SDRplay Mirics API Install Package V1.9.4 100%
Installing SDRplay RSP Mirics API library...
Architecture: x86_64
API Version: 1.8.1
Remove old libraries...
[sudo] password for rec:
Install /usr/local/lib/libmirsdrapi-rsp.so
Remove old header files...
Install /usr/local/include/mirsdrapi-rsp.h
Udev rules directory found, adding rules...
Libusb found, continuing...
Installing SoapySDRPlay...
Installing SoapySDR...
Finished.
2) Try SoapySDRUtil looking for SoapySDR::loadModule error
rec@pixil:~/Downloads$ SoapySDRUtil --probe
Probe device
[ERROR] SoapySDR::loadModule(/usr/local/lib/SoapySDR/modules/librtlsdrSupport.so)
dlopen() failed: /usr/local/lib/SoapySDR/modules/librtlsdrSupport.so: undefined symbol: _ZN8SoapySDR6Device18setFrontendMappingEiRKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE
mir_sdr_Init: gR=40dB fs=2.048MHz rf=222.064MHz bw=1.536MHz if=0.000MHz
mir_sdr_2500_Init: mir_sdr_usb_Init() failed
mir_sdr_Init: mir_sdr_2500_Init() Error 1
-- Device identification
driver=null
hardware=null
-- Peripheral summary
Channels: 0 Rx, 0 Tx
Timestamps: NO
3) Reinstall SoapySDR
rec@pixil:~/Downloads$ cd ~/Projects/SoapySDR
rec@pixil:~/Projects/SoapySDR$ cd ~/Projects/SoapySDR/build
rec@pixil:~/Projects/SoapySDR/build$ sudo make install
[ 82%] Built target SoapySDR
[ 91%] Built target SoapySDRUtil
[ 95%] Built target TestFormatParser
[100%] Built target TestTimeConversion
Install the project...
-- Install configuration: "Release"
-- Up-to-date: /usr/local/share/cmake/SoapySDR/SoapySDRConfig.cmake
-- Up-to-date: /usr/local/share/cmake/SoapySDR/SoapySDRUtil.cmake
-- Up-to-date: /usr/local/share/cmake/SoapySDR/SoapySDRConfigVersion.cmake
-- Up-to-date: /usr/local/include/SoapySDR
-- Up-to-date: /usr/local/include/SoapySDR/Errors.hpp
-- Up-to-date: /usr/local/include/SoapySDR/Config.hpp
-- Up-to-date: /usr/local/include/SoapySDR/Formats.h
-- Up-to-date: /usr/local/include/SoapySDR/Modules.h
-- Up-to-date: /usr/local/include/SoapySDR/Version.hpp
-- Up-to-date: /usr/local/include/SoapySDR/Types.h
-- Up-to-date: /usr/local/include/SoapySDR/Time.h
-- Up-to-date: /usr/local/include/SoapySDR/Device.hpp
-- Up-to-date: /usr/local/include/SoapySDR/Constants.h
-- Up-to-date: /usr/local/include/SoapySDR/Registry.hpp
-- Up-to-date: /usr/local/include/SoapySDR/Logger.hpp
-- Up-to-date: /usr/local/include/SoapySDR/Formats.hpp
-- Up-to-date: /usr/local/include/SoapySDR/Modules.hpp
-- Up-to-date: /usr/local/include/SoapySDR/Types.hpp
-- Up-to-date: /usr/local/include/SoapySDR/Time.hpp
-- Installing: /usr/local/lib/libSoapySDR.so.0.4.1
-- Installing: /usr/local/lib/libSoapySDR.so.0.4-2
-- Up-to-date: /usr/local/lib/pkgconfig/SoapySDR.pc
-- Installing: /usr/local/bin/SoapySDRUtil
-- Removed runtime path from "/usr/local/bin/SoapySDRUtil"
4) Probe again, still the error, but notice that the name of the missing symbol has changed.
rec@pixil:~/Projects/SoapySDR/build$ SoapySDRUtil --probe
Probe device
[ERROR] SoapySDR::loadModule(/usr/local/lib/SoapySDR/modules/libsdrPlaySupport.so)
dlopen() failed: /usr/local/lib/SoapySDR/modules/libsdrPlaySupport.so: undefined symbol: _ZN8SoapySDR6Device18setFrontendMappingEiRKSs
driver=null
hardware=null
Timestamps: NO
5) Install SoapyRTLSDR (not really relevant, I think)
rec@pixil:~/Projects/SoapySDR/build$ cd ~/Projects/SoapyRTLSDR/build
rec@pixil:~/Projects/SoapyRTLSDR/build$ sudo make install
[100%] Built target rtlsdrSupport
-- Up-to-date: /usr/local/lib/SoapySDR/modules/librtlsdrSupport.so
6) Probe again, still the error.
rec@pixil:~/Projects/SoapyRTLSDR/build$ SoapySDRUtil --probe
Probe device
driver=null
hardware=null
Timestamps: NO
7) Install SoapySDRPlay (what's with all these compile warnings? trying to instill confidence in your code hygiene?)
rec@pixil:~/Projects/SoapyRTLSDR/build$ cd ~/Projects/SoapySDRPlay/build/
rec@pixil:~/Projects/SoapySDRPlay/build$ sudo make install
Scanning dependencies of target sdrPlaySupport
[ 33%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Registation.cpp.o
In file included from /home/rec/Projects/SoapySDRPlay/Registation.cpp:25:0:
/home/rec/Projects/SoapySDRPlay/SoapySDRPlay.hpp: In constructor ‘SDRPlayGainPref::SDRPlayGainPref(double, double, double, int, int, int)’:
/home/rec/Projects/SoapySDRPlay/SoapySDRPlay.hpp:51:26: warning: ‘SDRPlayGainPref::grLNA’ will be initialized after [-Wreorder]
int grTarget, grMax, grLNA;
/home/rec/Projects/SoapySDRPlay/SoapySDRPlay.hpp:51:19: warning: ‘int SDRPlayGainPref::grMax’ [-Wreorder]
/home/rec/Projects/SoapySDRPlay/SoapySDRPlay.hpp:53:5: warning: when initialized here [-Wreorder]
SDRPlayGainPref(double lo, double min, double max, int targetGain = 40, int lnaGain = 24, int maxGain = 102) : loFreq(lo), freqMin(min), freqMax(max), grTarget(targetGain), grLNA(lnaGain), grMax(maxGain) { }
[ 66%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Settings.cpp.o
In file included from /home/rec/Projects/SoapySDRPlay/Settings.cpp:25:0:
/home/rec/Projects/SoapySDRPlay/Settings.cpp: In constructor ‘SoapySDRPlay::SoapySDRPlay(const Kwargs&)’:
/home/rec/Projects/SoapySDRPlay/Settings.cpp:32:18: warning: variable ‘err’ set but not used [-Wunused-but-set-variable]
mir_sdr_ErrT err;
/home/rec/Projects/SoapySDRPlay/Settings.cpp: In member function ‘virtual SoapySDR::Kwargs SoapySDRPlay::getHardwareInfo() const’:
/home/rec/Projects/SoapySDRPlay/Settings.cpp:81:18: warning: unused variable ‘err’ [-Wunused-variable]
mir_sdr_ErrT err;
[100%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Streaming.cpp.o
In file included from /home/rec/Projects/SoapySDRPlay/Streaming.cpp:25:0:
/home/rec/Projects/SoapySDRPlay/Streaming.cpp: In member function ‘virtual void SoapySDRPlay::closeStream(SoapySDR::Stream*)’:
/home/rec/Projects/SoapySDRPlay/Streaming.cpp:218:18: warning: variable ‘err’ set but not used [-Wunused-but-set-variable]
mir_sdr_ErrT err;
/home/rec/Projects/SoapySDRPlay/Streaming.cpp: In member function ‘virtual int SoapySDRPlay::readStream(SoapySDR::Stream*, void* const*, size_t, int&, long long int&, long int)’:
/home/rec/Projects/SoapySDRPlay/Streaming.cpp:573:34: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
int returnedElems = (numElems>bufferedElems)?bufferedElems:numElems;
Linking CXX shared module libsdrPlaySupport.so
[100%] Built target sdrPlaySupport
-- Installing: /usr/local/lib/SoapySDR/modules/libsdrPlaySupport.so
-- Removed runtime path from "/usr/local/lib/SoapySDR/modules/libsdrPlaySupport.so"
8) Probe one last time, and the error has disappeared!
rec@pixil:~/Projects/SoapySDRPlay/build$ SoapySDRUtil --probe
Probe device
driver=null
hardware=null
Timestamps: NO
I only noticed the change in the mangled symbol name while putting together this script. Maybe the sdrplay.com version of SoapySDRPlay is compiled with different options than SoapySDR?
-- rec -- ad5dz/1 --
