LSB Problem in SDRuno
PeterH
Postby PeterH » Mon Jul 11, 2016 4:43 pm
Just started using SDRuno and have a problem in that after starting the program and selecting LSB I get a pow:overflow error and log10:overflow error message and have to use Task Manager to close program. Functions fine in SDR Console 2.3. PC is a Windows 10 64 bit. Anyone else had this problem and perhaps knows the solution?
PeterH
Re: LSB Problem in SDRuno
Postby PeterH » Mon Jul 11, 2016 7:28 pm
FURTHER> Found this in the SDRuno Cookbook by Paul NN4F and Mike KD2KOG: SDRuno Reset
This is an easy way to reset SDRuno
reg delete "HKEY_CURRENT_USER\Software\SDRplay\SDRuno"
you can add the above text line to a notepad file and save as sdrunoreset.bat
then when you double click on it, it will delete the registry entries, or you can just paste it into a dos command prompt window.
This cleared up the problem and all working well again - thanks fellers!
