Help! RSP not listed as Input, windows 10
troy5
Postby troy5 » Tue Jul 12, 2016 4:46 pm
I'm trying to get my rsp to work with sdruno. Installation of driver and api worked flawless but the rsp is not listed as input device. Only microphone arrray is selectable. Device is listed in the device manager and seems to work (no warnings).
Does someone know how i could fix the issue.
THX
Re: Help! RSP not listed as Input, windows 10
Postby sdrplay » Tue Jul 12, 2016 4:53 pm
Not sure what you mean as not listed as an input?
If you start SDRuno with the RSP connected (and it's not in use by another SDR application) then you should see 4 buttons on the main window (LNA AGC ADV and PERF) - if you see them, then you are all set.
If not, it has not found the RSP.
troy5
Postby troy5 » Wed Jul 13, 2016 7:09 am
Ok Thanks!
I was confused because i had some kind of feedback noise and thought this was comming from my microphone. So I thought this was taken as the input device instead of the rsp!
Everything works ok now!
