Feature request
Feature request
Inconsistency between SSB steps when selecting modes, USB 500 Hz LSB 100 Hz
Default FM steps are 5 Khz at start-up, after setting to desired step, say 12.5Khz, can this be stored in the .ini so at next start the step defaults to last used.So say maintaining 12.5 Khz steps etc
Mode FM with NFM selected set step to 12.5 khz, change mode to MFM the step changes to 5 Khz,change back to NFM the step has defaulted to 5 Khz.
Thanks Keith
Thanks Keith
Re: Feature request
The step sizes can be changed by a right click in the RX window while hovering over the frequency digits. A menu will open with many choices. I tried this a moment ago, made some changes, closed SDRUno, reopened it, the changes appear to be saved. They were stored to the ini file. They may be lost if you ever reset the software to it's defaults.
Re: Feature request
I spoke too soon, you are correct - this doesn't work for FM and it's submodes
Re: Feature request
Is it possible to get Mem. Panel "Filter by VRX freq" to upper corner as a push button and text color orange when it's on? Like that
- button.jpg (189.34 KiB) Viewed 47084 times
