V 1.04 REC PANEL
G3MXH
V 1.04 REC PANEL
Postby G3MXH » Thu Oct 06, 2016 10:01 am
Downloaded V1.04 to check the recording and playback fix. I can save the recorded WAV file to a folder but when I click on the folder the wav files are not listed for selection. I can see and select these WAV files via Media player although, of course, they are not any use.
Re: V 1.04 REC PANEL
Postby jon » Thu Oct 06, 2016 11:10 am
To play back go to the MAIN module OPT button and select wav input and it will bring a file selector to select the recording you want
Then go to the REC Panel and the play button.
G3MXH
Postby G3MXH » Fri Oct 14, 2016 9:07 pm
Recording is now working well . I find this a very valuable feature.
Many thanks for your help.
WTF_Kenneth
Postby WTF_Kenneth » Sun Oct 16, 2016 4:11 am
The Record Panel's ((-)) icon, when depressed/highlighted, sets a loaded .wav file to replay in an infinite loop. Is there a way to get successive .wav files to play sequentially?
Postby sdrplay » Sun Oct 16, 2016 7:00 am
I just did a small test with 64MB files and it does automatically load one after the other if you don't have the repeat button enabled.
