What are the seven segment "0's" in the top right corners of the consoles?
Posted: Sun Oct 16, 2016 1:09 am
by bubblegumpi
0-00 or the main one says 0. Are these for opening multiple ones to listen to two things at once? What does the dash mean?
Also I heard that some one wrote a handbook or ultimate user guide on SDRUno. Does anyone have a link to download? Saw a guy with it printed out in a youtube video. And what the difference in Uno and Uno EXTIO?
Re: What are the seven segment "0's" in the top right corners of the consoles?
Posted: Sun Oct 16, 2016 6:49 am
by sdrplay
The first 0 represents the instance of SDRuno currently running. If you have more that one instance this value increases but they are 'aware' of each other for things like CAT and OmniRig control.
The 00 represents the VRX that you are currently using so that you can keep track of what VRX the various windows relate to.
The difference between the executables is that the EXTIO version ONLY works with non-RSP hardware via the EXTIO plugin interface. The EXTIO plugin needs to be in your Documents folder for it to be picked up by the software. The non EXTIO version ONLY works with the RSP.
