Not able to select Afedri SDR-Net Audio or mixer
Han
Postby Han » Sat Oct 22, 2016 1:33 pm
Hello
After using Studio1 for some time I would like to try SDRUno.
But I can't get it working with my Afedri.
The program starts but gives the following error:
Unspecified error in SoundStartln, error code 1
When I go to : -OPT -SELECT INPUT and try to select : Afedri Sdr-Net Audio it does not get selected. Also trying to select OPEN INPUT MIXER does not work.
I have put the SDR net control files in the the documents folder and the control box opens at the start of the program.
Any Idea what I am doing wrong?
dsalomon
Re: Not able to select Afedri SDR-Net Audio or mixer
Postby dsalomon » Sun Oct 23, 2016 1:25 pm
You do know that SDRUno is based on Studio1? If you're comfortable using Studio1, SDRUno will be second nature for you. SDRPlay hasn't made many cosmetic changes to it yet.
Sorry, I know this doesn't answer your question. I just wanted to make you aware.
I also have an Afeddir, which I will try to see if I can reproduce your problem. I will report back shortly.
73 - David, AG4F
NN4F
Contact:
Postby NN4F » Mon Oct 24, 2016 9:33 pm
Han wrote:Hello
You are running the extio version not the normal version ? There are two program icons one is for the RSP the other for EXTIO's if you have studio 1, you will not like Uno as it is restricted bandwidth for extio radios...
Paul - NN4F
Han
Postby Han » Tue Oct 25, 2016 9:51 am
Thanks Paul and David for the answers.
I am using the extio version, so that is not the problem.
I an using SDRUno because I hope this gets developed and studio 1 is not developed to much.
Han
Han
Postby Han » Tue Nov 01, 2016 6:09 am
problem solved
The settings od SDR control were incorrect and ( of course) the firewall from windows was playing tricks.
Thanks everyone for the help!
Han
Users browsing this forum: g1hbe and 5 guests
