Help a Newbie With Initial Setup Problem
wb2jix
Postby wb2jix » Fri Nov 11, 2016 9:39 pm
I was able to enter an FM broadcast frequency directly when I first initialized everything & it worked fine.
Now when I enter one, I see it in the tuner display, see the correct one in the waterfall however, the LO shows something different.
I must have changed some setting but I have no clue.
I enter 92.1, set it to FM, and the LO shows 342.53. I hear static but no radio station.
I don't see the signal in the waterfall either.
Is there a decent beginners document, more basic than the Cookbook, to be sure I get all the settings correct?
I also want to try the strong signal of my local NOAA station.
I'm not on Facebook nor do I want to be so that group is not an option for me.
Thanks!
Brian
Re: Help a Newbie With Initial Setup Problem
Postby sdrplay » Fri Nov 11, 2016 9:51 pm
When you are setting the frequency you need to type in kHz, so to get 93.0 MHz you would type 93000 and then hit return. As soon as you press . you are now typing in Hz
If that's not the problem drop us an email at support@sdrplay.com with a screenshot and we'll get you up and running.
Users browsing this forum: Bing [Bot] and 5 guests
