Record file size
KE2KB
Record file size
Postby KE2KB » Wed Dec 28, 2016 4:33 pm
Hi;
I have tried the record feature in SDRUno, and am interested in knowing whether there is a way to reduce the file size.
After about 30 mins of recording baseband, I have a total of about 5Gib in several files (each file is a max of about 2Gib).
Also, is there a way to change the default folder into which the saved .wav files are stored?
Frank - KE2KB
g4enz
Re: Record file size
Postby g4enz » Wed Dec 28, 2016 9:49 pm
Frank,
If you right click on the recording panel it will let you select the folder it will use to store your recordings. I don't know the answer to your question about file size.
73 Martin - G4ENZ
KE2KB
Postby KE2KB » Fri Dec 30, 2016 4:16 am
Thanks. I should have figured that out. Not really paying attention. Too much going on the radio :oops:
