Set-up Issue with HRD
Posted: Wed Jan 04, 2017 10:23 pm
by Cooperstown39
I would like to set-up HRD to control the SDRplay Pro2. Followed the instructions but I do not get the "Connected" message when clicking on the "Enable and Connect" box in the CAT settings. With the box checked, I just get the following error message;
VRX#0: The specified com device doesn't exist or is already open
Again, just trying to use HRD to control the SRDplay, no transceiver involved (that will come later).
Any all suggestions are welcome!
Re: Set-up Issue with HRD
Posted: Thu Jan 05, 2017 1:01 pm
by DanubeBCL
When HRD uses COM10 you must specify COM11 in SDRuno (or vice versa). You cannot use the same COM port on both sides unless you use splitters.
Which COM port emulator are you using? (VSPE, com0com, VSP Manager by K5FR...)
When you created the virtual COM port pair, did the emulator (VSPE, com0com, VSP Manager by K5FR or whatever you use) report success? If not, you are probably trying to create a pair from COM ports which are already in use. The emulator must report "OK" or something. Did you verify this in your emulator?
The image shows an example with VSPE.
Posted: Sat Jan 07, 2017 3:38 am
by Cooperstown39
DanubeBCL wrote:When HRD uses COM10 you must specify COM11 in SDRuno (or vice versa). You cannot use the same COM port on both sides unless you use splitters.
Thanks for the reply and the pic! I had the port set-up incorrectly. Everything is now working.
73
