Hi Z antenna port won't select on new RSP2
robpnelson
Postby robpnelson » Sat Jan 14, 2017 2:48 pm
I am having a problem setting up a new RSP2, using standard install of freshly downloaded SDRuno. PC is Windows 10. I am clicking around on the initial setup screen, and cannot select the HI Z port; I click on the button: and if the selected antenna was ANT A, no changes; if the selected antenna was ANT B, it switches to ANT A. I've tried this with the terminal block in and out of the device. Terminal block currently has 6 ft of hookup wire in the leftmost terminal, the other 2 with nothing.
Advice, please?
Re: Hi Z antenna port won't select on new RSP2
Postby Tech_Support » Sat Jan 14, 2017 3:11 pm
You can only select the Hi-Z port if your frequency is 30 MHz or below. Please check that you have set a frequency of less than 30 MHz before attempting to select the Hi-Z port.
