Different Band on each receiver
rick40c
Postby rick40c » Fri Feb 03, 2017 7:54 pm
Question is the RSP2 capable of listening to separate bands on each receiver at one time, I have only used mine for a few days but it seems that rec 2 and 3 are slaved to the primary receiver and I'm not able to choose a different band and on the 2nd and third receiver at the same time. I did notice that I can choose a different freq on each receiver but they have to remain within the band width and band I have chosen on receiver one. The reason I'm posting this is noticed on Ham Radio Outlets add that they show a screen shot of three receivers all on different bands so I'm assuming is can be done, Thanks in advance for the answer to what seems a dumb question I just assumed I could.
dlritter
Re: Different Band on each receiver
Postby dlritter » Fri Feb 03, 2017 11:22 pm
Sure, with multipule RSP's. Yes the Virtual RX's are limited to within the 8-10mhz scope of the 1st RX.
rick40c
Postby rick40c » Sat Feb 04, 2017 2:05 am
Thanks it Makes sense now I can vary with in the 8 to 10 MHz otherwise I need another RSP
zardoz99
Postby zardoz99 » Sat Feb 04, 2017 8:57 pm
If you look carefully at the selected frequencies, they are all within a 10 MHz span.
rick40c
Postby rick40c » Mon Feb 06, 2017 7:39 pm
No the Add on the Ham Radio Outlets page which is also a link to a You Tube Post show three separate bands 160 meters 40 meters and 80 meters all running at the the same time so I just assumed I would be able to, but I'm clear on it now. What the add doesn't tell you is there running three separate receivers.
Thanks, AA5AX rick40c
dlritter
Postby dlritter » Mon Feb 06, 2017 10:05 pm
Well, that is just 1.8 - 7.4 mhz so if the first rx was on the 80, with a 8mhz bw the vrx's could land on 160 and 40 mtr chunks. Yes?
Postby sdrplay » Tue Feb 21, 2017 11:33 am
To cover those frequencies I would...
VRX0: Frequency = 4.6MHz Sample Rate = 6MHz (just leave VRX0 sitting there) - you can increase the sample rate if you need to see more spectrum.
VRX1: Frequency = 1.8MHz
VRX2: Frequency = 7.4MHz
Then just use VRX1 and VRX2 to view each band (make sure they are enabled)
