Rx_Log_And_Tuner program
NoelUsher
Postby NoelUsher » Fri May 12, 2017 2:41 pm
Joachim Rabe has released an updated version of his
Rx_Log_And_Tuner excel/visual basic program.
This is a set of utilities that allows click and enter frequencies from EIBI and other sources and has two scan options.
One is a search between a lower and upper limit, the other is a search of user defined frequencies.
He added direct support for SDRuno.
This program will work with many SDR receivers. I suggest creating a folder to each SDR you own and copying the program to each folder and set that folder to match that SDR. I also own a Perseus and have experienced odd error when switching from the SDRuno to Perseus as the Perseus only receives up to 40MHz and a frequency higher then this produces an error.
The documentation is excellent.
The program can be found at: http://www.k-code.de/rx-tuner/.
Noel
