SDRuno Operation without SDR?
Tocnon
Postby Tocnon » Mon Sep 11, 2017 6:42 pm
I own the RSP2pro and have been using it quite a bit to capture wide frequency ranges to an RF WAV file... works great! My question is;
Can SDRuno be run without any SDR attached to the computer, for purposes of working with RF WAV recordings?
After capturing RF WAV files, I will go back through the data files at another time-- many times while away from my amateur radio station. The problem is that SDRuno won't start if the RSP is not connected to the computer. Please let me know if there is a way around this, strictly for working with recordings.
Thank you!
mikexeno
Re: SDRuno Operation without SDR?
Postby mikexeno » Tue Sep 12, 2017 5:25 pm
You can try using the EXT/IO edition of SDRuno and use the RSP2 EXT/IO dll. I have not tested this but it's worth trying.
Tocnon
Postby Tocnon » Tue Sep 26, 2017 8:35 pm
Mike, thanks for the info. This could possibly work, but would be a hassle to get two copies of SDRuno running on a single machine (possible?). It would be nice if the ability to run SDRplay for purposes of working with recorded RF wav files could be added in a future release. I understand the full version is essentially locked to the SDRplay receivers, so hopefully it can also be "locked" to the specific file format that SDRplay records to, so that it can be run without the SDRplay attached.
