FM Stereo problem for v1.22
avicsuk
Post by avicsuk » Wed Jan 24, 2018 3:44 am
I am a RSP2 user. After upgrading SDRuno to v1.22, it was found that when listening to commercial FM stereo broadcast, the audio became distorted like overloaded signal.This problem does not occur n v1.21 and SDR Console v3.
I have tried changing the IF and RF gain setting but the problem still exist.
Anyone have experienced the same problem with SDRuno v1.22?
pb1sam
Re: FM Stereo problem for v1.22
Post by pb1sam » Thu Jan 25, 2018 9:46 am
You have to lower the volume from SDRUno to 50% or less.
avicsuk
Post by avicsuk » Thu Jan 25, 2018 10:05 am
Thanks for the help. Problem solved.
When the reception mode was switched to WFM, the audio was not distorted even when setting the volume to 100%. Why the problem occurs to sterero reception only?
pb1sam
Post by pb1sam » Fri Jan 26, 2018 9:37 am
I shouldn't know. I am a newbie on SDR.
I bought a receiver last december.
I also mentioned that WFM reception is distorted.
After lowering down the SDRUno volume it sounds great.
IQbert
Post by IQbert » Tue Jan 30, 2018 11:52 pm
Also, be sure that your VFO is offset from your LO. Many issues can occur when don't offset them.
