How do you set the LO frequency?
Rsp1afan
Post by Rsp1afan » Sat Jan 27, 2018 12:26 pm
Not sure at the moment I will get use to the quirky SDRuno but simply how do you set the LO frequency? Do I need to keep changing this also ?
Re: How do you set the LO frequency?
Post by Tech_Support » Sat Jan 27, 2018 2:43 pm
When you first start SDRuno, the VFO and LO frequency will be the same. You need to click on the SP1 spectrum display with the mouse to create a separation between the LO and the VFO. Once you have done this, the LO will track the VFO with whatever offset you have established maintained, unless you have the LO Lock button in the main panel set.
To set the VFO frequency, you can either click on the frequency display in the Rx Control panel and type the frequency directly, or hover the mouse over the frequency display and use the scroll wheel of the mouse.
All of this is covered in the SDRuno manual what comes with the installation of the software and can be accessed via the options button (OPT) on the Main Panel.
