What do you run with SDRuno?
mbott
Post by mbott » Wed Apr 18, 2018 1:26 pm
SDRuno is my preferred software with the SDRplay RSP2 and generally the first software that I fire up when HF listening. But, I also find that CSVUserListBrowser, Audacity & DX Toolbox are convenient to run. What other software do you find useful to you?
Mike
Sony ICF-2010 Sangean ATS-909X Icom IC-R71A & IC-7300 Tecsun PL-660 Kenwood R-1000 & R-5000 Yeasu FRG-7 SDRplay RSP2 & RSPduo Airspy HF+ & Discovery JRC NRD-535D CountyComm GP-5/SSB Pixel RF Pro-1B Wellbrook ALA1530LNP
NoelC
Re: What do you run with SDRuno?
Post by NoelC » Wed May 23, 2018 8:32 pm
I like to decode digital signals and CW from time to time, and a ham friend of mine (some 300 miles distant) is often curious about what ham communications I can pick up, so I've tied speakers out to line in with a small cable and occasionally run:
- FLDIGI to decode CW and rtty
- I tried YAND but found fldigi did just as well.
- WSJTX to decode ham comms
- I ran MULTIPSK at some point to try to decode beacons and was successful, but I don't regularly use it.
-Noel
hfaero
Post by hfaero » Wed May 23, 2018 8:47 pm
With SDRUno and my RSP2 I use MultiPSK via a Realtek audio mixer to decode SELCAL codes. I also use MultiPSK with all other software as it's the only SELCAL decoder that works and has a shifter for the AF view.
Cheers,
HF Aeronautical Specialist
maximusmike55
Post by maximusmike55 » Wed May 23, 2018 10:40 pm
With both my RSP1 and RSP2, I am only interested in utility monitoring (I am a bit deaf, so voice listening is no longer practical). I use SDRUno through virtual audio cable to MultiPSK most of the time as frankly that covers virtually everything I need.
With this set-up I can monitor most utilities from HF up to L-Band with excellent results, just needs a bunch of antennae.
Mike
Last edited by maximusmike55 on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
