Is it safer to Transmist?
4s6ryd
Post by 4s6ryd » Sat May 05, 2018 7:27 am
Thank you for getting me in.
I have Yeasu FTDx-3000D and RSP2Pro Port A connected to the Rx Out of the rig. Using OmniRig and receiving and controlling the rig works perfect.
My worry is, can I transmit (have a QSO) while the SDR is still connected to the rig and the computer? I use 100W and gap between the SDR and the radio is about 3 feet.
Is there anything else I need to setup?
mikeladd
Re: Is it safer to Transmist?
Post by mikeladd » Sun May 06, 2018 5:12 pm
The RX out port of the FTDX3000 will go to GND when you keyup. The RSP is 100% safe when you tether to that port (or the IF out port)
4s6ryd
Post by 4s6ryd » Mon May 07, 2018 3:19 am
Thank you Mike
I will start transmitting then.
Cheers
73
