SP1 Waterfall flowing up
I'm new to RSP1A / SDRUno v1.22 so this is likely a nubie issue but I can't find it in the manual.
I did something that seems to have caused the waterfall in the sp1 window to flow "up" not down.
I went through the menus and can't find anything obvious.
Re: SP1 Waterfall flowing up
I think you must have ticked the 'WF reverse' box. To correct it, click the SETT button which is top left on the MAIN SP frame. In the box that appears, you'll find the check-box at the bottom right.
