Starting second tuner window on RSP Dup
jlwebuser
Post by jlwebuser » Mon Jul 23, 2018 7:10 pm
I think i'm missing an obvious step. I Have a SDR Duo and have been using it in single tuner mode.
Now i have a second antenna and I want to start it up in dual tuner mode. But I can't find how to get the control window for the second tuner to open up. I'm sure its something obvious i'm missing.
The screen shot is attached, and i'm using V1.23 (Duo build).
John
Patrick73
Re: Starting second tuner window on RSP Dup
Post by Patrick73 » Tue Jul 24, 2018 5:35 am
Hi John,
After you have selected 'dual mode' (normal mode) and declared the frequency you're tuned to as 'master' (MAIN > OPT > Auto Layouts > RSPduo Master), you simply have to tune to another frequency and then start a 2nd instance of SDRuno (i.e launch it a second time). It will "detect" that uno is already running. Declare this 2nd instance as "RSPduo Slave" ; done !
Patrick
jlwebuser
Post by jlwebuser » Tue Jul 24, 2018 3:34 pm
Thanks!!
I missed that I had to start a second instance.
Working like a charm doing head to head antenna comparisons.
John
