Reinitialize SDR without closing/restarting SDRUno?
Posted: Thu Aug 23, 2018 11:27 pm
Occasionally when using SDRUno v1.23 with an RSPduo, I need to stop the receiver in SDRUno's Main window and unplug the USB connection between the RSPduo and the PC to make a hardware adjustment.
If I do this and then reconnect the USB cable and press "Play!" in SDRUno's Main window, I get an error:
SDRUno Error: Device cannot be initialized (sdrplay_api_Fail)
Currently I'm resolving this by closing all SDRUno windows and then restarting SDRUno. This solves the problem, but also means I have to do a significant amount of tweaking to multiple virtual receivers that are running.
So, if I have to unplug and replug the USB cable between the RSPduo and the PC, is there any other way besides closing and restarting SDRUno to get it initialized again?
