IARU Region 1 S-Meter Std Selection
Posted: Wed Oct 10, 2018 8:30 pm
by WA9ZVF
I believe I basically understand that checking the box to select the "IARU Region 1 S-Meter Std" basically says S9 is a 50 microvolt signal into 50 ohms. I may be missing some details. The question is, if the box is not checked how is the calibration then defined? What's the distinction between the two options?
Ray Mikula
WA9ZVF
Re: IARU Region 1 S-Meter Std Selection
Posted: Thu Oct 11, 2018 3:58 am
by Roger
From
https://en.wikipedia.org/wiki/S_meter#I ... dation_R.1
"IARU Region 1 Technical Recommendation R.1 defines
S9 for the HF bands to be a receiver input power of -73 dBm. This is a level of 50 microvolts at the receiver's antenna input assuming the input impedance of the receiver is 50 ohms.
For
VHF bands the recommendation defines S9 to be a receiver input power of -93 dBm. This is the equivalent of 5 microvolts in 50 ohms."
Posted: Thu Oct 11, 2018 5:41 am
by Tech_Support
Hello Ray,
As Roger pointed out, IARU region one specification changes the definition of s9 from -73 dBm to -93 dBm for VHF frequencies and greater. if you un-check this box, s9 will remain at -73 dBm for all frequencies.
