Beginner Questions
Robert11
Beginner Questions
Post by Robert11 » Sat Oct 20, 2018 6:22 pm
Beginner. A few very basic questions please, that I could not find in documentation.
a. My understanding is that the RF Gain is (only) set by the RFATTEN slider.
That there is no other RF Gain adj. True ?
And that the slider has no effect if the the AGC is set to ON. Is this correct ?
But, if I do move it, I can attenuate more. So, how does the slider
interact with the automatic AGC ?
b. For “normal” listening of 30 MHz and below, do you folks suggest a slow or a fast setting for the AGC ? Above 30 MHz ?
c. Where is the volume adj. for audio output ?
d. When would one use the synchronous am detector option ? All the time, or...?
Much thanks,
Appreciate the help,
Bob
Re: Beginner Questions
Post by Paul » Sat Oct 20, 2018 9:15 pm
I hope that the following may help:
?B: Slow works fine for me below 30 Mhz
?C: Volume control slider is the yellow bar at the botoom of the RX Ctlr pane
?D: See P30-31 of user manual (easy access via the SDRuno MAIN panel under "opt." It is the preferred mode for AM.
I'll leave the rest to the experts...
Post by Tech_Support » Sat Oct 20, 2018 9:50 pm
Robert11 wrote:Hello,
Much thanks,
Bob
Hello Bob,
Regarding the questions on AGC and RF gain control, I recommend that you have a read of the following application note:
https://www.sdrplay.com/wp-content/uplo ... SDRuno.pdf
Please note this is also covered on our Youtube channel application note AN009: https://www.youtube.com/watch?v=bGHwY8J ... e=youtu.be
