Very slow start of SDRuno 1min 10s
K3EK-F5MWA
Postby K3EK-F5MWA » Sat Nov 24, 2018 3:35 am
Hello everybody,
I started using SDRuno with the RSP2Pro and was very happy with it.
I bought the SDRduo and installed the new software. The installation was fine, but I've to wait for more than 1 minute to have the program started.
Otherwise no other problems. CAT works fine, everything seems just fine. Has somebody else noticed this kind of behavior? Could there be a conflict with the old SDRuno which I unistalled some time ago? Perhaps has some data remained in the registry? The computer works fine with either SDRConsole 3 or HDSDR which start in seconds.
Thank you in advance for your help.
Kind regards
Ezio K3EK - F5MWA
Re: Very slow start of SDRuno 1min 10s
Postby g1hbe » Sat Nov 24, 2018 9:18 am
Hi Ezio.
It might be worth trying 'reset to factory settings' in the MAIN/OPT menu.
K3EK-F5MWA
Postby K3EK-F5MWA » Sat Nov 24, 2018 8:51 pm
Hello Andy,
Many thanks for the suggestion which I quickly applied but with almost no results, the time was only shortened by 10 seconds...Prior to the resetting, the program asked if I agreed that all registry would be reset and I accepted.
I tried to reinstall with same results. I used Revo unistaller to make sure all registry entries were deleted but this did not help either. All other programs, HDSDR and Console V 3 pop up in seconds as the previous SDRuno I used with the RSP2Pro (and which was uninstalled). I'll have to contact the SDRPlay support to ask for help. My computer is an I5 with Windows 10, 8Gb memory and a 1 Tb SSD, so the problem is elsewhere.
Thanks again for trying.
73
Ezio - K3EK/F5MWA
Postby Mike2459 » Mon Nov 26, 2018 12:15 pm
You can use Windows 10 Pro's Performance Monitor to view the PC's activity while SDRUno is starting. It may provide a hint. Also review the event log at that point in time.
Users browsing this forum: Strykar and 3 guests
