EXTio.exe missing
Bo Barry
EXTio.exe missing
Postby Bo Barry » Tue Dec 18, 2018 8:34 pm
It's gone, and I can't find it on the web. It was a separate program, not the EXTIO Installer program.
I'm trying to use my RTL_SDR with SDRUNO, and there is no provision to insert the proper DLL.
Loving my RSP2Pro tho.
Help appreciated.
Bo W4GHV since '54
Re: EXTio.exe missing
Postby Paul » Wed Dec 19, 2018 10:36 am
May I suggest that you try SDR SHARP as an alternative, which is also an excellent programme that would support your device. Good luck.
Postby Tech_Support » Wed Dec 19, 2018 12:58 pm
If you install release 1.22 of SDRuno, then the ExtIO version is automatically installed in the same installation directory as the RSP version of SDRuno. There is no ExtIO version under release 1.23 or later.
There is no problem with having both release 1.22 and release 1.24.1 (current) on the same machine. Just ensure that they are installed in different directories.
bobarry
Postby bobarry » Wed Dec 19, 2018 3:01 pm
Thanks for the replies.
I did the latter and it worked immediately but only one time!
I enabled bias-t and changed the disabled to Q input and it worked great.
Next time only the disabled option was available.
Will tinker more and get the sequence figured out.
Now I need some sunspots or contest to capture some good signals.
Thanks. Bo
