Ghost program on WFM - RSPduo
Patrick73
Post by Patrick73 » Tue Mar 19, 2019 10:36 am
Hi buddies,
I have an issue when tuned to 88.1 FM (+ some other frequencies) where I hear a station actually transmitting on 103.9 (their 0.1 kW TX is about 1km from home, -31dBm). Switching from LIF to ZIF, using decimation, adjusting manually the AGC does not help.
Lowering the RF Gain of course makes this harmonic disappear but I then I can not hear the "real" (weak) station on 88.1 because of lack of gain ...
No such problem using another well-known SDR.
How can I fix it ?
Thanks for the precious support.
Re: Ghost program on WFM - RSPduo
Post by glovisol » Tue Mar 19, 2019 11:59 am
In order to avoid front end overload, you should insert a 20 dB attenuator between antenna lead & RSP input. This is not necessary with other SDR because most probably they are less sensitive.
Patrick73
Post by Patrick73 » Tue Mar 19, 2019 12:59 pm
The other SDR is, at least, as sensitive. I suppose it better handles huge signals.
Unfortunately, I have no attenuator on hand to improve my duo performance, bad luck. I thought I was doing something wrong with its settings.
In any case, thanks for the advice. This is not a big issue, I can live with it ;-)
