having trouble using 1.3 with Afedri SDR-net
jaypea500
Postby jaypea500 » Sun Mar 24, 2019 3:31 am
I downloaded and installed the new SDRUno version 1.3, de-installing the previous version and cleaning the registry prior to install. I was able to use the old version with both my RSP2 and my Afedri SDR-Net, using separate shortcuts to start the regular (used with RSP2) and EXTIO versions (used with Afedri.
now, with 1.3, I can't seem to make it work. I can use the RSP2 without problem, but I can find no way to use the Afedri. I can find no separate EXTIO exe to start the program. I've installed using both the SDRUno and the EXTIO installers and can not get it to work. when I try to start the program, it throws an error 'cause either it can't find the RSP2 or it can't start the SDRplay service.
can someone please point me in the right direction here? the previous version worked gangbusters with both radios. I'd like to do the same here.
TTTBTIA! ("thanks to the brain trust in advance!)
...joe
Re: having trouble using 1.3 with Afedri SDR-net
Postby Mike2459 » Sun Mar 24, 2019 7:45 am
You should be able to reinstall your old version and it will coexist with sdruno 1.3 as long as you install to a separate folder.
Postby Tech_Support » Sun Mar 24, 2019 8:54 am
Hello Joe,
The ExtIO version of SDRuno only comes with the 1.22 install. As Mike2459 says, You can install this alongside release 1.3 as long as you select a different installation directory.
