Can't get omnirig + SRDuno + FT991A to talk
M0JKW
Post by M0JKW » Wed May 29, 2019 8:23 pm
Hi - I have the following setup:
Windows 10 64 bit PC running Omnirig connected to my Yaesu FT-991A
I know that Omnirig is working because I use CommCat for logging and I can tune my radio both ways with the radio tuning commcat and commcat tuning the radio.
If I have CommCat running then SDRuno shows 'Can't connect to OmniRig server'
If I close CommCat I get some very strange behaviour as follows:
* SDRuno can see my radio RIG1 typeL FT-991, status: On-line and used by: Inst.#0 VRX0
* SDRuno can set my FT-991A's MODE and my BAND
* My FT-991A can set SDRuno's MODE and BAND
* SDRuno cannot tune the FT-991A and the FT-991A cannot tune SDRuno
* If I toggle off then back on RSYN1, the FT-991A jumps to a set frequency (for example on 20m it jumps to 14.17500
I have reinstalled Omnirig but I am pretty sure that's not the problem as it works with other programs (commcat)
I have reinstalled SDRuno - still no joy
I'm at a bit of a loss as to what is happening - any ideas?
thanks in advance for your help.
M0JKW
Re: Can't get omnirig + SRDuno + FT991A to talk
Post by M0JKW » Thu May 30, 2019 6:05 am
Quick update. Unchecking the 'sync centre frequency' box in the omnirig settings seems to have fixed sdruno syncing with the yaesu problem.
It seems commcat has a problem with omnirig in that it completely takes it over and won't allow another program to use omnirigs com port but I have logging working at the same time as running sdruno with log4om so i am happy.
Hopefully someone else experiencing the same issues may find this helpful.
Thanks.
