Scanner Is Pretty Good, But...
NORVIN
Post by NORVIN » Sat Jun 15, 2019 10:55 pm
It needs some improvements. It seems like it uses the same way that the Frequency Manager Suite plugin for SDR# uses and will stop to the sides (but not on) a strong active frequency sometimes. I would suggest instead using the way the Russian RTL-SDR FrequencyManager plugin for SDR# does it by actually stopping on the exact frequency if active regardless of strength.
Re: Scanner Is Pretty Good, But...
Post by sdrplay » Sun Jun 16, 2019 8:27 am
The SDRuno scanner is purely a channelised system. If the specified step size is smaller than the specified audio bandwidth and if the threshold isn't optimised, then it could settle on the sides of a signal, but if used correctly that's not really likely.
NORVIN
Post by NORVIN » Sun Jun 16, 2019 4:24 pm
If the threshold is raised to avoid this then weaker signals will not be stopped on during scans.
