Problems with Memory Bank Files
Posted: Mon Jun 27, 2016 6:14 pm
I'm running SDRuno on two different Win7Pro laptops and it works fine (OK, works fine with acknowledgement of the previously-mentioned bugs listed in other message threads) with one exception...
On one of the laptops, I was trying to edit one of the memory bank files; specifically, I was trying to copy an entry from one file to another using the clipboard. It seemed to be working fine, one line at a time, then something happened and the program terminated.
Now, when I start up SDRuno, everything works EXCEPT when I try to open or save a memory bank file. When I do, it gives me the following warning message: "SDRuno internal error: the application will terminate." If I change users and run the program (as the system administrator or not), I have no problem... ONLY under the user account where I first experienced the problem do I continue to have this issue. Rebooting doesn't solve the problem. I've even uninstalled and reinstalled the program with no change. Run it under a different account and everything is fine... but not the one where I first experienced the problem. I can import a copy of the EiBi CSV file and it works, except for when I try to save it, then it crashes.
I can put the memory files on a thumbdrive and access them just fine from another user account, so it's not the files that are corrupt.
Obviously, the program is storing something somewhere with respect to memory bank files in that one user account, but I don't know what it is, or where it's at to either fix it or kill it.
Any ideas?
Rick, WD8KEl
Any ideas?
Rick, WD8KEl
