What is on everyone's SDRplay V2.0 wish list?
MiamiC70
Postby MiamiC70 » Sun Oct 09, 2016 10:18 pm
Re: What is on everyone's SDRplay V2.0 wish list?
Postby g1hbe » Mon Oct 10, 2016 8:31 am
The only one that springs to mind is much-improved front-end filtering. The images of FM and DAB that 'get in the way' are numerous, wspecially around the 250 MHz satellite band. External filters can get around this, but it's messy. Some tight up-front filters would be most welcome.
Oh, and two separate antenna inputs for HF (say up to 30 MHz) and VHF/UHF.
Sasan
Postby Sasan » Mon Oct 10, 2016 10:52 am
Metal case
Better (and more) filters
Mitigating FM images
Using an external clock source (like GPS sources) for frequency stability
DF2HF, NM9A, EP2C
F1BJB
Postby F1BJB » Sun Oct 16, 2016 6:16 pm
A way to switch external filters or aerials depending of the frequency tuning.
Too many internal filters will increase cost and induce problems in the overlapping zones.
May be the use of switched notch filters inside the SDRplay would be a better solution.
neok
Postby neok » Mon Oct 17, 2016 8:40 am
Compatibility with th linux OS? wish...
DK7OB
Postby DK7OB » Mon Oct 17, 2016 9:12 am
Software wishes:
- Open source API for Linux
- SDRUno for Linux :lol:
micked
Postby micked » Mon Oct 17, 2016 5:55 pm
Tcxo
Two antenna inputs
Software switchable bias-t
jacobcarl
Postby jacobcarl » Wed Oct 19, 2016 10:27 am
It stricks for design ,API anbd images
9a4db
Postby 9a4db » Thu Oct 20, 2016 9:21 pm
On board utility connector with clk input and I2c lines....
Applications->
interferometry and coherent receivers.
Passive radars, Direction finding etc....
rgood123
Postby rgood123 » Fri Oct 21, 2016 12:44 pm
Optional snap-in standalone pcb board + case can be use as a multi-band portable radio without a computer
Users browsing this forum: Google [Bot] and 8 guests
