Install Question
Install Question
Received my SDRplay today and I'm about to start installing software. I've read the instructions, and 'm still confused. The SDRuno file says it contains the installer, yet other instructions say to install the API first. Is the "API" te "installer"?
Also, when I begin the installation, should the SDRplay be connected to my PC, or is it connected after the software is installed?
I'm using Windows 7
I'm using Windows 7
Re: Install Question
WA2SQQ, SDRuno contains the DRIVER and all else you need to use the SDRPlay for normal listening. Unless you plan on using the Mirics HW or interfacing your SW with the SDRPlay, I don't think you need anything else. I installed all the stuff on the Start Here page on my DT but when I used my LT, I installed only SDRuno. The installer (DL here) will tell you when to connect your SDR. Good luck and enjoy, John.
Thanks - I got it working.
Is there a link that describes how to integrate the SWL database that is written by the person in Germany? Will SDRuno import it directly, or is some sort of interface software required? I'm thinking, the later is going to be required.
look at our cook book, the back section has step by step guide for the database... Http://www.nn4f.com/index.php/sdrplay-guides.htmlWA2SQQ wrote:Thanks - I got it working.
Paul - NN4F
