Decode
Ricar1969
Decode
Postby Ricar1969 » Tue Jun 30, 2015 5:10 pm
Hi there, Have yet to purchase the SDRPLAY but will I need a Virtual Audio Cable in order to decode data on HF like with the RTL Dongles.
Regards Richard
Re: Decode
Postby Tech_Support » Tue Jun 30, 2015 5:49 pm
Hi Richard,
For digitally encoded signals on HF such as DRM, if you use something like HDSDR or SDR# to control the RSP, you will still need a virtual audio cable to pipe the output to decoding software. The RSP simply selects the wanted signal but does not perform any signal processing.
ON4LL
Re: Decode
Postby ON4LL » Tue Jun 30, 2015 7:41 pm
The internal mixer of windows does the trick.
It is buildin windows so no additinal software to pipe the audio is needed
Ricar1969
Re: Decode
Postby Ricar1969 » Tue Jun 30, 2015 9:54 pm
Many thanks to all for the response, Richard
CaptainNemo
Re: Decode
Postby CaptainNemo » Wed Jul 01, 2015 8:45 am
ON4LL wrote:The internal mixer of windows does the trick.
Hi ON4ALL.
I'm using WIN7 professional on LENOVO T410.
I never succeeded in doing that with ms win mixer (I'm currently using vb-cable)
Can you please post some hint how to do it with ms win mixer?
TNX
bye
Re: Decode
Postby g1hbe » Wed Jul 01, 2015 11:34 am
Hi ON4ALL.
TNX
bye
Same here, I've never succeeded in getting the audio from SDR# back into DSD+ using just the mixer. I usually endup in a terrible mess......
Qosmio
Re: Decode
Postby Qosmio » Thu Jul 02, 2015 5:45 am
I had the same problem with sdrplay and a RTL Stick, The problem occurs with fldigi and DSD+. I have a IDT soundcard (HP laptop 8560w onboard version) running on windows 8.1 x64 and with the drivers of the soundcard it was not possible until i used the default wdm drivers from Windows. So it seems to be a driver issue if you can or cannot use the soundcard internal mixer of the soundcard in conjuction with sdrplay.
ON4LL
Re: Decode
Postby ON4LL » Mon Jul 06, 2015 8:55 am
I can't see the problem.
I have the windows stereo mixer, enabled it and that's it
DSD+ was just working
If somebody would like to have the VAC (no demo) , just send me a mail :-)
Ricar1969
Re: Decode
Postby Ricar1969 » Fri Jul 10, 2015 5:13 pm
Please note that the VAC that ON4LL is offering is a PIRATE copy so take care and download at your own risk, Richard
