Using SDRPlay with a HF Transceiver
on6dp
Re: Using SDRPlay with a HF Transceiver
Post by on6dp » Sun Aug 28, 2016 4:53 pm
Paul (NN4F)
Can you help me?
I have a SDRPlay.It's connected to Omnirig via uRouter from Microham
It's running in CAT but my problem is that I don't know which connection I must put into the SMA connector
Indeed, I have made a modif from my FT-2000D to take the IF 69,450 MHz.
Can I put that cable to the SMA Connector. Must I absoluletly connect an HF Antenna into SDRPlay.
When I doing that it's running withput problem but I don't have CAT.
How can I do?
73 de Paul, ON6DP
73 de Paul, ON6DP / OP0P
