Just on a whim I tried to build, and surprisingly cmake works fine:
root@pine64:/opt/SoapySDRPlay/build# cmake ../
-- The CXX compiler identification is GNU 4.9.2
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type not specified: defaulting to release.
-- Found libsdrplay: /usr/local/include, /usr/local/lib/libmirsdrapi-rsp.so
-- LIBSDRPLAY_INCLUDE_DIRS - /usr/local/include
-- LIBSDRPLAY_LIBRARIES - /usr/local/lib/libmirsdrapi-rsp.so
-- Performing Test HAS_STD_CXX11
-- Performing Test HAS_STD_CXX11 - Success
-- Configuring done
-- Generating done
-- Build files have been written to: /opt/SoapySDRPlay/build
make[2]: *** No rule to make target '/usr/local/lib/libmirsdrapi-rsp.so', needed by 'libsdrPlaySupport.so'. Stop.
CMakeFiles/Makefile2:60: recipe for target 'CMakeFiles/sdrPlaySupport.dir/all' failed
make[1]: *** [CMakeFiles/sdrPlaySupport.dir/all] Error 2
Makefile:117: recipe for target 'all' failed
make: *** [all] Error 2
Any ideas?
