Win xp rsp 1
lauchlin
Win xp rsp 1
Postby lauchlin » Tue Jan 24, 2017 3:54 am
Can't get play to work with hdsdr and rsp 1 the xp computer will support usb 2 any ideas thanks
VE7SHM
Re: Win xp rsp 1
Postby Tech_Support » Tue Jan 24, 2017 12:01 pm
We are not aware of any issues with XP and the RSP1. Presumably all was good with the previous version of HDSDR (2.7)?
Have you tried SDRuno to see if that works and confirm that it is a issue specifically related to the HDSDR install and not a H/W connectivity issue?
lauchlin
Re: Win xp rsp 1
Postby lauchlin » Tue Jan 24, 2017 1:53 pm
I am helping a fellow Ham hes 200 miles from me so its hard to see hands on whats going on other to say keep getting errors in setup with console them in hdsdr can't find the rsp1 ?? .............
i
VE7SHM
Re: Win xp rsp 1
Postby Tech_Support » Tue Jan 24, 2017 3:58 pm
He really needs to check that the device is enumerating correctly. If he can see the device in the device manager, then it will be enumerating. If not, then the problem is a communication problem between his PC and the RSP1. In this scenario, the problem could be his USB cable (which might be faulty) or the driver may not have loaded correctly.
RiverPatrol1
Re: Win xp rsp 1
Postby RiverPatrol1 » Thu Jan 26, 2017 2:33 am
There is a issue that I had with HDSDR and and old Dell XP dual core CPU that I was using for ADS-B. I tried to put HDSDR on it as it was light for an old system like that and I started getting error messages when trying to start it up. It turned out that the old CPU wasn't capable of some math functions and when I got in touch with the author of HDSDR he knew exactly what it was and sent me a ExtIO specifically for the problem. If it turns out to be that problem then I have a copy of it .
Last edited by RiverPatrol1 on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
MiamiC70
Re: Win xp rsp 1
Postby MiamiC70 » Sat Jan 28, 2017 9:25 pm
Windows XP? :shock:
lauchlin
Re: Win xp rsp 1
Postby lauchlin » Sun Jan 29, 2017 2:29 pm
MiamiC70 wrote:Windows XP? :shock:
Oh i know rsp 1 is running on his xp box but not very good could not get hdsdr working but console 2 is but its sounds like its not stable not sure what console 1.5 was like i personally never tried it ?? .................
VE7SHM
