Weather fax reception
seakayak
Postby seakayak » Sat Jan 28, 2017 3:32 pm
Can someone tell me how to receive Weather faxes with the RSP1? I know how to tune in the frequency but how do I convert it to the Wx fax?
I'm new to SDR and still learning. Don't know much other than just receiving what I see.
tnx in advance
ic706mk2
Re: Weather fax reception
Postby ic706mk2 » Sat Jan 28, 2017 5:14 pm
Hi Kurd,
Wat wil je ontvangen hf of vhf??
Op +- 137Mhz zijn de sats direct te ontvangen bij "doorgang" of wil je de wxfaxen op kg?
Grts
ON7KEC
ic706mk2
Postby ic706mk2 » Sat Jan 28, 2017 5:18 pm
Rx on HF or on VHF???
Grts
Luc
seakayak
Postby seakayak » Sun Jan 29, 2017 2:44 pm
Mostly on HF.. However if I can get it on VHF I'd try it.
seakayak
Postby seakayak » Sun Jan 29, 2017 2:45 pm
ic706mk2 wrote:Hi,
Grts
Luc
HF mostly however if I can get it on VHF I'd like to try that. Wasn't aware it was on VHF
ic706mk2
Postby ic706mk2 » Sun Jan 29, 2017 4:52 pm
hi,
first of all..
you need following software...
audio:
vbaudio.jcedeveloppment.com
DEcoding vhfsats
http://www.wxtoimg.com/
Sat Trackingyou can used also for reception with your sdrplay....
SDR-Console – version 3.0 preview 5 in the downloadmap here on sdrplay http://sdr-satellites.com/Tracking
here you find some explanation: http://sdrplay.com/community/viewtopic.php?t=557
For hf reception you can use mixw or fldigi
I hope i did help you to start with weather reception??
Greets
seakayak
Postby seakayak » Thu Feb 02, 2017 7:55 pm
I am running CubicSdr .. Does anyone know were the INPUT audio or OUTPUT audio connections are??
seakayak
Postby seakayak » Fri Feb 03, 2017 8:01 pm
I downloaded Fldigi and got it running. Does anyone know a Virtual cable program that will run on MAC?
I'm almost there.. thanks for everyones help..
Sasan
Postby Sasan » Sat Feb 04, 2017 8:39 am
seakayak wrote:I downloaded Fldigi and got it running. Does anyone know a Virtual cable program that will run on MAC?
You can use "soundflower" or "loopback" on OS X
DF2HF, NM9A, EP2C
