Can't install sdr play with hdsdr
Wizard6733
Postby Wizard6733 » Sat Feb 04, 2017 10:14 am
I installed the api and ext10 for use with hdsdr on xp sp3 32bit and every time I go to launch hdsdr it asks which ext10 I want to use I pick sdrplay.dll and I get this error message and I've reinstalled the api/ext10 several times and the same happens....any help would be great
Failed to load api registry entry
HKEY_LOCAL_MACHINE\software\MinicsSDR\tools error 127
Re: Can't install sdr play with hdsdr
Postby g1hbe » Sat Feb 04, 2017 10:55 am
Wizard - go to the facebook SDRPlay group and post your problem there. I think this has come up before and the guys there will know what to do.
Wizard6733
Postby Wizard6733 » Sat Feb 04, 2017 11:15 am
I posted about it yesterday and got no replies...I'll post it again and see what happens..thanks
Btw I did a Google search of the exact error and got 1 hit on this forum but it never said what they did to fix it
Postby g1hbe » Sat Feb 04, 2017 12:24 pm
I hope you sort it. I know there is a problem with XP but I can't remember what it is or how you are meant to fix it. But fixable it is. Good luck.
Postby sdrplay » Sat Feb 04, 2017 12:27 pm
Uninstall any API you have installed, then go to our downloads page (http://www.sdrplay.com/downloads) and select either of the following from the Windows tab...
HDSDR - VERSION 2.75 BETA3
or
EXTIO PLUGINS - VERSION 1.0
Wizard6733
Postby Wizard6733 » Sat Feb 04, 2017 12:56 pm
At first I put in api/hardware 1.97 and then hdsdr then rsp1 extio 3.9.1 from http://www.sdrplay.com/windows.html
When that didn't work I uninstalled both api and extio and put in the hdsdr version 2.75 beta3 and when that didn't work I uninstalled all that and put in extio version 1 both from http://www.sdrplay.com/downloads/ and it still didn't work...I'll mess with it later. I may try to put in the sdruno and see if it works...I don't like uno but just to see if it works or not. If I can't get hdsdr to work with rsp1 I'll just put it away till I get another operation system
Wizard6733
Postby Wizard6733 » Sat Feb 04, 2017 1:24 pm
I hate to completely uninstall hdsdr cause my rtl still works on it and I don't want to lose it also. When I try to run hdsdr it asks me which dll I want to use the rtl 2832.dll or whatever the number is or I can choose the sdrplay.dll and when I chos the sdrplay.dll I get the error message btw I don't have the rtl plugged in while trying to use rsp1
DanubeBCL
Postby DanubeBCL » Sat Feb 04, 2017 6:32 pm
Have a look at your HDSDR programme folder.
Are there two dlls
ExtIO_SDRplay_RSP1.dll, modified date 2016/12/23
ExtIO_SDRplay_RSP2.dll, modified date 2016/12/22 ?
If not, you loaded a false or outdated ExtIO_.
The download package EXTIO PLUGINS - VERSION 1.0 automatically does everything right. You need no extra API installer. Did you choose the HDSDR programme directory when prompted where to install the ExtIO_s?
73s, Heinrich
Wizard6733
Postby Wizard6733 » Sat Feb 04, 2017 7:18 pm
I just uninstalled api and extio ....restarted and ran sdrplay extio installer 1.0 from ur download section for windows .... I didn't have the RSP plugged in when I ran it and half way thru it said to plug in RSP...I did and the program finished and I had to go to programs/sdrplay and copy the extio_sdrplay_rsp1.DLL and put into hdsdr folder myself cause it wasn't in there....then I clicked hdsdr and it asked if I wanted to use extio_sdrplay_rsp1.DLL and I clicked it and it Spain no RSP found....I tried all 4 USB ports and nothing
Wizard6733
Postby Wizard6733 » Sat Feb 04, 2017 7:37 pm
I uninstalled it and ran it again and this time it put the rsp1.DLL in hdsdr but when I choose it it still says no RSP found....I tried another cable and it did the same thing so who knows
